999068709169
Unconstrained FPGA input
After checking unconstrained paths report I am wondering for a source sync.input data.
  1. Would it make sense if I use "offset in" constraint for Input Pad to IODELAY2 ? (even when phase detection is enabled)
  2. Can I ignore the unconstrained path?
Extra info:
I have source synchronous data and clock coming to FPGA (spartan 6 100 , PlanAhead 14,6)
I am using a ISERDES2 primitive deserializer to deserialize the data.
Phase detection is already enabled  Would it make sense if I still use "offset in" constraint?
viviany
1. I guess you're referring to using OFFSET IN to constrain the path from input pad to ISERDES. Input pad to IDELAY is not a valid timing path. And the answer is no. When you use IDELAY in variable mode, you don't need to add OFFSET IN constraint.
2. It depands. Some unconstrained paths can be ignored but some cannot. What unconstrained path do you have?
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
999068709169
  1. From the differential clock input to the internal registers (which are driven by the outputs of PLL,differential clock is PLL input)
  2. From the differential data input to the iserdes.m and iserdes_s. (Total delay is fixed for 9 different channels and 1.674ns)
viviany
----AR#18392 answers this.
http://www.xilinx.com/support/answers/18392.htm
You can just ignore this kind of paths
----If these are the paths from the differential data to the data input of the ISERDES and you're using IDELAY in variable mode on these paths, you can ignore them.
