12-16-2019 09:20 AM
Until and before vivado 2019.1, I was able to use the following create_generated_clock command in an xdc file:
create_generated_clock -name <name_of_clock> [get_pins <output_pin_of_bufg_gt>]
to name the output of a bufg_gt where the input clock was divided by 2 like in the instance below:
BUFG_GT bufg_gt_inst ( .CE ( 1'b1 ), .CEMASK ( 1'b0 ), .CLR ( rst ), .CLRMASK ( 1'b0 ), .DIV (2 ), .I ( input_clk ), .O ( output_clk ) );
In this case, given the right path of the output pin of the bufg_gt, the tool was able to figure out the relationship between the input and the output of the bufg_gt.
With Vivado 2019.2, the same command throws the following ctritical warning only during implementation phase and not during synthesis:
[Constraints 18-851] Could not find an automatically derived clock matching the supplied criteria for renaming. [“<name_of_constraint_file>”]
This causes the the constraints post this definition to not be recognized.
In order to solve this, I had to re-write the command more explicity, defining the source and and the relationship between the input and the output of the bufg_gt like below:
create_generated_clock -source [get_pins <input_pin_of_bufg_gt>] -add -master_clock [get_clocks <name_of_master_clock>] -divide_by 2 -name <name_of_clock> [get_pins <output_pin_of_bufg_gt>]
Here are my questions:
1. Is this change expected?
2. Is there a more elegant/efficient way to write this in order to get vivado 2019.2 to recognize the output clock of the bufg_gt?
3. Is there a way to write this where I dont have to explicity mention the relationsip between the input and the output clock of the bufg_gt (i.e the -divide_by 2 in this case) and have the tool recognize this? I would prefer that becasue the value I pass in to the DIV parameter of the bufg_gt might differ in certain setups of my design and I would prefer not having to keep changing my constraints setup for it.
Thanks in advance!
12-16-2019 04:50 PM
Thanks for reporting this. I don`t think this is expected change.
Re-naming can work on automatically derived clock, so I doubt if there is really such clock on there.
Can you confirm it?
Takayoshi
12-16-2019 07:22 PM - edited 12-16-2019 07:52 PM
Hi Takayoshi,
I do see an "automatically derived clock" on that target pin when I run "report_clocks" but the intention here is to rename the clock to something that makes more sense in our design.
12-16-2019 10:35 PM
Thanks for confirming. Yes, I understood.
You see such warnings when you try to re-name on pin where automatically derived clock not exist.
You actually see clock, then this might be SW issue.
Another possibility is order constraint, but the truth your work around was working denied it.
I test it in 2019.2, and was not able to reproduce the issue.
Can you share reproduce design with me?
12-17-2019 02:36 PM
When using create_generated_clock to rename a clock, you cannot use the -divide_by option (and other options) as described on pg 92 of UG903(v2019.1).
The following post may help with using create_generated_clock to rename a clock.
https://forums.xilinx.com/t5/Timing-Analysis/BUFGMUX-constraints-and-Vivado/td-p/1052538
Mark
12-17-2019 03:08 PM
Unfortunately, I cannot share the design but I will try to reproduce this is more contained setup and share that
12-17-2019 04:46 PM
If you can provide reproduce design, I will address it so that we can fix it in future release.
In the meantime, how about this ?
set IN_PERIOD [get_property PERIOD [get_clocks -of [get_pins <input_pin_of_bufg_gt>]]]
set OUT_PERIOD [get_property PERIOD [get_clocks -of [get_pins <output_pin_of_bufg_gt>]]]
set DIV [expr $OUT_PERIOD/$IN_PERIOD]
create_generated_clock -source [get_pins <input_pin_of_bufg_gt>] -add -master_clock [get_clocks <name_of_master_clock>] -divide_by $DIV -name <name_of_clock> [get_pins <output_pin_of_bufg_gt>]
12-18-2019 01:25 PM
Hi Mark,
I am now using create_generated_clock with -divide_by and it seems to be working fine -- vivado 2019.2 picks it and replaces the auto generated clock names with it. I did refer to UG903 for it. I think what happens is a new clock is created (I also use the -add argument) with the specified name since divide_by is used and replaces the vivado generated name, I am not sure though. When running "report_clocks" after this, I do not see the vivado generated names for these clocks, I only see the names that I passed using create_generated_clock (when -divide_by was used)
I do agree this is a bit unexpected especially since constraints that were working until 2019.1 do not work on 2019.2.
12-18-2019 02:55 PM
Hi Takayos,
Thanks this worked.
