sprd_mgq
Vivado IDE timing analysis issue.
Hi,I have a question about Vivado timing analysis. On the page215 of UG906,a typical slack equation is given: Data Required Time (setup)= capture edge time  + destination clock path delay - clock uncertainty - setup time.
But,when I read the timing summary in my Vivado project,the setup time is plus not minus when derived the Data Required Time. Just like the graphic below.Why this conflict happened?
avrumw
Guide
Guide
The setup time of the flip-flop itself is -0.044ns (slightly negative).
When the timing report subtracts a negative number, the two minus signs cancel, and it looks like addition.
Avrum
avrumw
Guide
Guide
Avrum
sprd_mgq
Thanks a lot for your reply. I'd like to accept your answer as a reasonable conclusion although it is hard for me to understand a negtive setup time.
avrumw
Guide
Guide
Take a look at this similar post that discusses negative setup times.
Avrum
