02-24-2013 02:36 PM
In Vivado, Edit Timing Constraints, create clock option, there is an option "add clock", you can tick it or not. What does it mean if I tick it? (see attachment)
It confused me since I firstly think this means I want to add the clock into my target file, however that can be done through clicking
"Apply".
Thanks very much.
02-24-2013 05:30 PM
The -add is typically used when you attempt to define a different clock period requirement on the same object.
So let's take a slightly different example.
create_clock -period 10.000 -name system_clk_1 -waveform {0.000 5.000} [get_nets o_clk_g]
create_clock -period 5.000 -name system_clk_2 -waveform {0.000 2.500} -add [get_nets o_clk_g]
Without -add, the second constraint will override the first one, so that the period requirement of o_clk_g is 5 ns.
With add, clock name "system_clk_1" and "system_clk_2" coexist, and both requirement will be analyzed.
02-24-2013 04:53 PM
You can type "create_clock -help" in Tcl console to see what "-add" option means.
-add - (Optional) Define multiple clocks on the same source for
simultaneous analysis with different clock waveforms. Use -name to specify
the new clock to add. If you do not specify this option, the create_clock
command will automatically assign a name and will overwrite any existing
clock of the same name.
02-24-2013 05:09 PM
Thanks, I checked it and try it in edit timing constraint. But I don't understand the description very well (maybe my English is bad). Let us take an example to help me to understand:
create_clock -period 5.000 -name system_clk_1 -waveform {0.000 2.500} [get_nets o_clk_g]
Does this mean I create two clocks in XDC "system_clk_1" and "system_clk_2" with the same source "o_clk_g"? Whay will happen if withouth the "-add" ?
Thanks very much.
02-24-2013 05:30 PM
02-24-2013 05:33 PM
