What does this timing warning mean, please?
I'm using Vivado 2017.1 and I'm new at trying to get a project to meet timing.  I get the following summary of Inter-Clock setup issues:
I believe I understand Path 685, and I am currently addressing it.
I do not, however, understand the four with yellow arrows.  Those seem to be WARNINGS.  Below is detail for Path 688.  Hopefully it's large enough for you to read.  (If not, I think you can zoom your browser view.  Chrome uses control-mousewheel.)
So why does this have a yellow arrow, which I assume is a warning?  Note that "ROIC_stream_fifo" is a clock domain crossing FIFO.  The source and destination signals seem to be INSIDE this fifo.  Here's the instantiation:
    i_ROIC_stream_fifo_dout ROIC_stream_fifo_dout();    // Instance the interface
    FIFO_ROIC_stream_two_clk ROIC_stream_fifo (
        .rst(rst0),
        .wr_clk(ROIC_stream_fifo_din.din.ROIC_clkdiv7),
        .rd_clk(clk),
        .din(ROIC_stream_fifo_din.din.data),
        .wr_en(ROIC_stream_fifo_din.din.wr_en),
        .rd_en(ROIC_stream_fifo_dout.dout.rd_en),
        .dout(ROIC_stream_fifo_dout.dout.data),
        .full(ROIC_stream_fifo_din.din.full),
        .prog_full(ROIC_stream_fifo_din.din.prog_full),
        .empty(ROIC_stream_fifo_dout.dout.empty)
and note that the data is 117 bits.  I see [0] through [1] in the original summary (first image above), so if that's data, it's not warning about all the bits.
Anyway, I would think everything should be fine when using this FIFO.  So is that yellow arrow actually a warning or not?  And if it is, why and how do I get rid of it, if at all?
Thanks very much,
Helmut
Voyager
Voyager
Hey @helmutforren,
No, that yellow arrow is just a yellow arrow ...
See this other thread.
Best,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Hey @helmutforren,
Best,
Herbert
