eng_man
What maximum frequency will mean here??
I implement this system
	 Port (
			  clk,clks,rest  in  STD_LOGIC;
			           lo   : out  STD_LOGIC;
	end main;
       begin
        process(clk,.........)
        process(clks,........)
        process(synchronization signal)
   end
 the synthesizer report give me the following
Timing Summary:
Speed Grade: -4
Minimum period: 25.668ns (Maximum Frequency: 38.959MHz)
Minimum input arrival time before clock: 4.297ns
Maximum output required time after clock: 4.283ns
Timing constraint: Default period analysis for Clock 'clk'
Clock period: 25.668ns (frequency: 38.959MHz)
Total number of paths / destination ports: 132221536213 / 1277
Timing constraint: Default period analysis for Clock 'clks'
Clock period: 4.142ns (frequency: 241.429MHz)
Total number of paths / destination ports: 525 / 70
can any one explain what maximum freq here mean???
i think their is no meaning du to that maximum clk freq 38MHZ
and maximum for clks 241MHZ
i am really confuse
can any help what these reprot meaning exactlly
I am tired of the traditions of peoples --
All I want is to live freely with the girl which I love --
But this is impossible because the traditions of the people stronger than me.
austin
Two clocks,
clk and clks
Each has its own maximum frequency
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
Two clocks,
clk and clks
Austin Lesea
Principal Engineer
Xilinx San Jose
eng_man
thank you austin
did you know that i have wait you for two day!!
i was fair that you was busy and will not back to the forum soon
your answers always like gifts in holidays
bassman59
Historian
Historian
@eng_man wrote:
thank you austin
"Wait for two day?"
Austin posted his (correct) answer two hours and forty minutes after you posted your question!
austin
b,
That might have been his second post.  I think I read it on Friday, and thought I'd give someone else a chance to reply (as the answer was in the question).
Austin Lesea
Principal Engineer
Xilinx San Jose
eng_man
@bassman59 wrote:
@eng_man wrote:
thank you austin
"Wait for two day?"
I DID NOT MEAN FOR THIS POST that i wait him
eng_man
@austin wrote:
b,
yes austin
thank ,
ywu
Check http://myfpgablog.blogspot.com/2010/11/understand-maximum-frequency-reporting.html to see if it helps.
@eng_man wrote:
	 Port (
			           lo   : out  STD_LOGIC;
	end main;
       begin
   end
Timing Summary:
Speed Grade: -4
i am really confuse
Cheers,
Jim
eng_man
@eng_man wrote:
	 Port (
			           lo   : out  STD_LOGIC;
	end main;
       begin
   end
Timing Summary:
Speed Grade: -4
i am really confuse
thank you
