Why is my reset treated as a clock ?
In my design I have a reset port which is connected to reset on fpga board. This is showing up as a clock in timing constraints wizard.
Is there any switch to add exception to such cases ?
Tags (2)
Hi @anjaneyulu.challa9,
Can you show us that reset port through synthesized design? Snapshots will be helpful to understand. And also provide the constraint file which you have applied.
hemangd
hemangd
WHat language / tools you using ?
My bet is that the reset signal is used some where in the code as a clock, the tools are quite good at noticing that.
     BTW: that could be a latch you have created with the reset,
Have you looked through the outputs on the terminal window
    particularly the warnings, anything strange, like latches inferred , signals removed that you think should not be ?
Please check the reset signal connectivity in implemented design. What is the fanout of the reset? Can it be that a BUFG is inserted?
@graces fan out is around 3000 and yes a BUFG is inserted
@drjohnsmith I'm using verilog and vivado. I dont see that reset is used as a clock anywhere in the design. No warnings as such
Hi @hemangd ,
Here is the snap shot of synthesized design and no extra constraints applied other than the pin locs
2018-07-05 08_37_56-192.168.24.226_6 (inhyvnc12.inedasystems.com_6 (achalla)) - VNC Viewer.png
And also provide the snapshot of timing constraint wizard where you see this reset as a clock.
hemangd
hemangd
Hi @hemangd ,
Sorry I have attached the wrong schematic Please find the attachemnts below 2018-07-05 10_09_28-192.168.24.226_6 (inhyvnc12.inedasystems.com_6 (achalla)) - VNC Viewer.png2018-07-05 10_11_04-192.168.24.226_6 (inhyvnc12.inedasystems.com_6 (achalla)) - VNC Viewer.png
@anjaneyulu.challa9 wrote:
Hi @hemangd ,
In your schematic, select the net right after the BUFG, and then go to "Net Properties -> Connectivity or Cell Pins" to see if this net drives any CLK pins of sequential elements.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
No it doesn't drive any clocks
Does it drive any G pin of latches?
-vivian
Guide
Guide
If the timing constraint wizard is identifying the net as a clock, then it is most likely driving a clock (or gate of a latch) pin somewhere in the design.
The tools can help you find it - open the synthesized design and type:
show_objects [filter  [all_fanout -flat -endpoints_only [get_ports CPU_RESET]] "IS_CLOCK && IS_LEAF"]
Avrum
