999068709169
Why output of PLLs are Unconstrained Paths
Dear Gurus,
I have an input clock on my top as below
    T2_CLK_p 			: in std_logic;
    T2_CLK_n 			: in std_logic;
 I have a constraint as below
   NET "T2_CLK_p" TNM_NET = "T2_CLK_p";
   TIMESPEC TS_T2_CLK_p = PERIOD "T2_CLK_p" 3 ns HIGH 50 %;
   NET "T2_CLK_n" TNM_NET = "T2_CLK_n";
   TIMESPEC TS_T2_CLK_n = PERIOD "T2_CLK_n" 3 ns HIGH 50 %;
When I run Trace Report I see some register to register paths as unconstraint path.
The source clock and the destination clock is the same clock which is output of PLL.
What am I doing wrong?
999068709169
I am using  PlanAhead 14.6, Spartan 6 100 ( XC6SLX100csg484-3)
smarell
Community Manager
Community Manager
Please check the .bld report and make sure that the clock constraint is propagated through the PLL. Additionally check the clocking interaction report (tsi).
sampatd
Also, you don't need to set the period constraint on clk_p and clk_n. Period constraint on clk_p should be enough.
Comment out the clk_n constraint and see if the period constraint propagates through PLL.
brucey
Have you other FROM TO constraints related?
brucey
