ssampath
Voyager
Voyager
Will vivado tool suggest best frequency for my design for the choosen board or part ?
Hi Friends,
Am using vivado 2018.2 and Xilinx part xc7v2000tflg1925-1.
am getting routing issues most of times and some times bit stream is generating. i understood congestion is high as pin LOCs are not properly allocated while designing the external board.
i tried without timing  then there is no issue in PNR. so i want to know what is the best max frequecy i can use so that i will not get any PNR issues ?
Any help or suggestions are highly appreaciated.
-Sampath
-Sampath
@ssampath
Just added in the 6Dec19 version of UG949 is “Assessing the Maximum Frequency of the Design” - on page 208.
Mark
@ssampath
Mark
