Zynq-7020 BUFMR Min Period Violation
I'm using a Zynq-7020 (xc7z020clg484-1), and I'm trying to use a BUFMR to forward a 500 MHz clock signal from an MMCM in one bank to a BUFIO in an adjacent bank.  After routing, I'm getting a timing violation on the BUFMR.  Specifically, it's a Pulse Width (Min Period) violation.  Vivado (2017.4) says the minimum required period is 2.155 ns, which translates to 464 MHz.
According to the Data Sheet (DS187 2018-07-02), "The maximum input frequency to the BUFR and BUFMR is the BUFIO Fmax frequency."  For -1 speed grade, Fmax_bufio is 600 MHz;  however, Fmax_bufh is 464 MHz, and Fmax_bufg is 464 MHz.
So my question is, which is the correct Fmax for a BUFMR?  The Datasheet that says the BUFMR Fmax should be same as BUFIO (600 MHz), or Vivado (2017.4) which says Fmax is same as a BUFG/BUFH (464 MHz)?
回复: Zynq-7020 BUFMR Min Period Violation
The documentation is correct. There has been similar speed file issues for different architecture like Artix-7. A CR has been filed to request speed file update.
Re: Zynq-7020 BUFMR Min Period Violation
[edit: deleted after editing original post]
I'm having exactly the same issue on a 7014 with vivado 2019.1. Anybody know the answer?
Looks to be a speed file issue. The speed file value doesn't match the documentation.
I'll file a CR to dev team.
Is there a way to disable the pulse width check? set_false_path doesn't seem to work. Or a way to edit the 'speed file'?
To disable the pulse width check on this pin also disables other timing check related it, which is not recommended.
You can just ignore this false check on this pin.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Can you confirm that the documentation is indeed correct? Or could it be a documentation issue?
Before ignoring a timing violation like this, it would be important to have a definitive statement from Xilinx.  "Looks to be a speed file issue" probably wouldn't cut it as the basis for ignoring a timing violation if it ultimately resulted in a failure in our product.
