rakesh_bansal
clarification regarding combinational flag in create_generated_clock constraint
Hi @avrumw,
 In post :
https://forums.xilinx.com/t5/Timing-Analysis/Vivado-and-BUFGMUX-timing/td-p/444448
I see that you have mentioned following :
create_generated_clock -name clk1_post -source [get_pins BUFGMUX_inst/I0] -combinatorial [get_pins BUFGMUX_inst/O]
create_generated_clock -name clk2_post -source [get_pins BUFGMUX_inst/I1] -combinatorial [get_pins BUFGMUX_inst/O] -add.
Quick clarification needed :
1) I believe we need to use -master_clock option too, otherwise Vivado (v2017.2) tool throws warning that no _master_clock is defined.
2) You are using -combinational flag because generated clock (out of BUFGMUX) is travelling through combinational logic of mux, right? And that input to this logic (of MUX) is a clock.
Something like :
clockA-->Combo_logic-->clock_out.
In this case combo logic is mux.
a) But if we have simple AND gate of clock gating logic, then also same principle will hold true and we will need -combinational flag to create_generate_clock at output of AND gate w.r.t. the clock coming to inputs of AND gate, right?
b) What if, if the input to mux is another generated_clock based on some source clock. There also can we use -combinational flag? Circuit is something like :
source_clock-->Genereted_clock-->combo_1-->clock_out.
But there is an AR to put constraints :
https://www.xilinx.com/support/answers/59484.html
And there i don't see any -combinational flag in constraints. Can you please let me know what am i missing here?
Best Regards,
RB
avrumw
Expert
Expert
Please don't post the same question twice. I replied to the question in the other post.
Avrum
avrumw
Expert
Expert
Avrum
rakesh_bansal
Hi @avrumw,
I created this new post because the previous post, on which i queried, was closed. And i thought you might not get notification because previous post is closed. But i think i was wrong and you got notification there.
I have updated my reply on same post (https://forums.xilinx.com/t5/Timing-Analysis/Vivado-and-BUFGMUX-timing/m-p/786960#M12166).
Thanks and Regards,
RB
