oh__oh
constraints
I have question about clock constraints in VIVADO 2020.2
my verilog code is here :
module top(
LED,clk
input clk;
output reg [3:0] LED = 4'b0;
reg [31:0] counter = 32'b0;
always @(posedge clk) begin
if(counter==32'd125000000) begin
LED <= LED +1;
counter <= 0;
end else begin
counter <= counter +1;
end
end
and constraints is  here :
set_property PACKAGE_PIN D18 [get_ports {LED[3]}]
set_property PACKAGE_PIN G14 [get_ports {LED[2]}]
set_property PACKAGE_PIN M15 [get_ports {LED[1]}]
set_property PACKAGE_PIN M14 [get_ports {LED[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports {LED[3]}]
set_property IOSTANDARD LVCMOS33 [get_ports {LED[2]}]
set_property IOSTANDARD LVCMOS33 [get_ports {LED[1]}]
set_property IOSTANDARD LVCMOS33 [get_ports {LED[0]}]
set_property PACKAGE_PIN L16 [get_ports clk]
set_property IOSTANDARD LVCMOS33 [get_ports clk]
create_clock -period 10 -name clk [get_ports clk]
and there is error message :
[Timing 38-313] There are no user specified timing constraints. Timing constraints are needed for proper timing analysis.
Q1) I don't know why I get an error message.
Q2) is there anything wrong with my constraints file?
my board is zybo-z7-10 and enviroment is VIVADO 2020.2
miker
@oh__oh
I ran your code and constraints targeting the Zybo-Z7-10 and it had timing constraints present and passed:
I attached my Vivado 2020.2 Project Archive for you to review.
Please Reply, Kudos, and Accept as Solution.
