studentofdsi
dividing system clock frequency
hi i am using virtex 4 ml403 eval board. the system clock frequency is 100MHZ and i am interfacing an ADC to this fpga board. the Clock requirement of ADC is 500khz and i need to divide the system clock of fpga to 500khz so i can use it as input clock to ADC..can anyone suggest how to implement this and how to write the vhdl code for this..any example code..
thanks
gszakacs
Professor
Professor
Your code divides the clock by 2^7 or 256.  That gives 390.625 KHz.  My suggestion to place the clock output in an IOB flip-flop would be easier if you make it registered like:
process(clk)      -- system clock
  if rising_edge(clk) then
    div <= div +1;
    clkdiv <= div(7); -- This adds a register that can easily be pushed in to the IOB (no feedback)
  end if;
end process;
If you want to divide by something other than a power of two, then you need to add more logic to restrict the count.  This is one way to divide by 200 with 50% duty cycle:
signal div :natural range is 0 to 199;
signal clkdiv : std_logic;
    if div = 99 then
      clkdiv <= '1';
    elsif div = 199 then
      clkdiv <= '0';
      div <= 0;
    else
      div <= div +1;
    endif
  end if;
end process;
-- Gabor
yashp
To divide frequency in Virtex 4 you can use DCM.
To know more about DCM refer this link: http://www.xilinx.com/support/documentation/user_guides/ug070.pdf {Page # 55}
Yash
gszakacs
Professor
Professor
You can't get such a low frequency from a DCM.  However it's not that hard to generate this frequency using counters.  To get a clean signal at the ADC, I'd recommend using an IOB flip-flop for the output.
100 MHz divided by 500 KHz is 200.
So effectively you want to divide by 200.  If you need a square wave, then the obvious way is to divide the 100 MHz by 100 to get 1 MHz, and then divide that by 2 to get a 50% duty cycle waveform at 500 KHz.
There should be plenty of counter examples in the language templates.
-- Gabor
studentofdsi
could you just put it here ..how to divide using counters..vhdl code of it.. is it something like this..
signal div :std_logic_vector (7 downto 0 );
signal clkdiv;
div <= div +1;
end if;
end process;
clkdiv <= div(7)
will this give me close to 400khz ??
kkn
Yes, your counter signal clkdiv will be able to drive approx 400 Khz clock when the input clk is 100 Mhz.
--Krishna
gszakacs
Professor
Professor
    div <= div +1;
  end if;
end process;
    if div = 99 then
      clkdiv <= '1';
      clkdiv <= '0';
      div <= 0;
    else
      div <= div +1;
    endif
  end if;
end process;
-- Gabor
studentofdsi
ok thanks i will try it out.. but i didnt get thst IOB .. what is that ??
gszakacs
Professor
Professor
IOB (I think this originally stood for Input/Ouput Block) refers to the logic block associated with each I/O pin.  The flip-flops in these blocks have very consistent timing from clock to output pin, and setup to clock.  It generally makes your board-level design simpler when you use registers in the IOB, especially when you are concerned with the relative timing between output pins (source synchronous design).
-- Gabor
studentofdsi
ok got it..
gszakacs
Professor
Professor
I just wanted to clean up some issues with the code I posted earlier.  That code had some syntax errors (sorry VHDL is not my native language).  It also would have gotten stuck with div at 99.  To help in simulation I also added a reset.  Here's the update:
signal clk : STD_LOGIC;
signal rst : STD_LOGIC;
signal clkdiv : STD_LOGIC;
signal div :  natural range 0 to 199;
process (clk)  -- system clock
begin
    if (rst = '1') then
      div <= 0;
      clkdiv <= '0';
    elsif div = 99 then
      clkdiv <= '1';
      div <= div +1;  -- must increment or it gets stuck at 99!
      clkdiv <= '0';
      div <= 0;
    else
      div <= div +1;
    end if;
  end if;
-- Gabor
studentofdsi
k done..
