Anonymous
Not applicable
external feedback path for DCMs
Hi Everybody,
i'm trying to get my feedback clock for DCM off chip and back again for certain purposes.
And, I want to see the results in timing analyzer. First, i tried it single ended, connected signals
and pins etc, supplied following constraint as it requested by the tool:
NET "CLKFBP_I"     FEEDBACK = 100 ps NET "CLKFBP_O";
this worked perfect. I can see the results in timing anayzer as well.
But, in second step, i wanted to use differential signals for clock feedback.
All i did was, adding OBUFDS and IBUFDS buffers to design and specifed signal standard  LVDS_25.
But now , software complains that the loop incomplete is and i don't see any deskew effect of DCM of course.
In differential case my constraint looks like:
NET "CLKFBN_I"     FEEDBACK = 100 ps NET "CLKFBN_O";
or
NET "CLKFB*_I"     FEEDBACK = 100 ps NET "CLKFB*_O";
in both case no success.
Quick check in constraints guide:
"The basic UCF syntax is:
NET feedback_signal FEEDBACK =value units NEToutput_signal;
where
• feedback_signal is the name of the input pad net used as the feedback to the DCM
• value is the board trace delay calculated or measured by you
• units is either ns or ps. The default is ns.
• output_signal is the name of the output pad net driven by the DCM
FEEDBACK Propagation Rules
Both the feedback_signal and output_signal must correspond to pad nets. If attached to any
other net, an error results. The feedback_signal must be an input pad and output_signal must
be an output pad.
In my constraints net names are indeed the pad nets.
I don't know why in differential case feedback loop is not detected by the tool.
Has anyone also experienced something like this?
Thanks &
Anonymous
Not applicable
Re: external feedback path for DCMs
Sorry, just to make it more complete:
input buffer is not IBUFDS, its IBUFGDS of course, being a GCLK pin.
And, at output path, there is ODDR2 with D0,D1 connected to GND and VCC.
(output of the DDR  is same like CLock itself)
And, i used ISE 10.1.
