Prakhar
how to write $setuphold task for a bus ?
I want to write specify block for a bus [2:0] A
Please let me know which kind of coding should I choose and why
specify
1) $setuphold (posedge CLK, posedge A, 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay);
$setuphold (posedge CLK, negedge A, 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay);
2) $setuphold (posedge CLK, posedge A[0], 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay[0]);
$setuphold (posedge CLK, posedge A[1], 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay[1]);
$setuphold (posedge CLK, posedge A[2], 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay[2]);
$setuphold (posedge CLK, negedge A[0], 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay[0]);
$setuphold (posedge CLK, negedge A[1], 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay[1]);
$setuphold (posedge CLK, negedge A[2], 0:0:0, 0:0:0, notifier_a, enable_a, enable_a, CLKA_delay,A_delay[2]);
endspecify
yashp
Sorry but I am not sure what are you trying to achieve here, can you please share details?
This forum is for STA regarding analysis/constraints issue, after you provide the details I may be help you to direct to correct forum.
Yash
