Participant sarit8
mmcm CLOCKOUT1 high fanout
In the timing summary report I can see that I have timing issues (high fanout = 15136) from the  CLOCKOUT1  of the mmcm.
Relevant schematic is attached, and the timing report.
How can I fix the timing issue from the CLOCKOUT1  of the mmcm (e.g   Source:                 clk_rst_ctrl_i/clk_wiz_0_i/inst/mmcm_adv_inst/CLKOUT1,   Destination:            rx_top_i/demoder_i/corr_res_i/rd_ptr_reg[1]/CE)
p.s
I use phys_opt_design command.
Tags (2)
Re: mmcm CLOCKOUT1 high fanout
refer this ARs
https://www.xilinx.com/support/answers/9410.html
Thanks and Regards
Balkrishan
Guide avrumw
Guide
This is the same thing as your other post.
A high fanout of a clock is expected - this is why the clock buffers exist. But they are only used to drive clock pins of clocked cells.
Here again, you have the clock signal driving the CE of a cell - this is not a clock pin, and hence should never be directly reached by a clock signal - either directly from the MMCM or through a clock buffer.
Avrum
Hi @sarit8,
If everything is clear for you on this subject, please mark the thread as solved.
Kind Regards,
Florent
Florent
