Anonymous
Not applicable
no clocks in design
Hai,
      I am using Vivado, kintex-7. After synthesis, i am doing timing analysis. but report_clocks showing no clock found in the design. But i defined the clock as fallows
balkris
http://www.xilinx.com/support/answers/55248.html
Thanks and Regards
Balkrishan
graces
Did you receive any critical warning with regards to the create_clock command?
What's the clocking topology like?
Anonymous
Not applicable
hai,
   no critical warning. I am using board clock coming from oscillator
balkris
can you please send your code. I would like to reproduce at my end
Thanks and Regards
Balkrishan
Anonymous
Not applicable
hai,
    i can't send design.. when i give command report_clocks, showing
WARNING: [Vivado 12-3502] Design has no clocks defined.
viviany
What do you get if you run the following constraint in Tcl console in the Synthesized design?
create_clock -name CLK_108MHz -period 9.26 -waveform {0 4.63} [get_ports CLK_108MHz]
And what do you get if you then run report_clocks after running the above constraint?
-Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
