11223344
pulse_width_clock check_timing warning for GigE IP in Artix 7
I have the same issue that was described in:
https://forums.xilinx.com/t5/Timing-Analysis/quot-Register-Latch-pins-need-pulse-width-check-quot-on-GTP-in/td-p/630383
but no solution seems to have been provided for that old post.
I find that the same issue is present in a GigE IP example design with Vivado 2018.3 and an Artix-7 part. Check Timing does not report any missing clock, but it does report 2 pulse_width_clock warnings:
        Register/Latch pins need pulse width check (2)
        core_wrapper_i/inst/pcs_pma_block_i/transceiver_inst/gtwizard_inst/inst/gtwizard_i/gt0_GTWIZARD_i/gtpe2_i/PLL0CLK
        core_wrapper_i/inst/pcs_pma_block_i/transceiver_inst/gtwizard_inst/inst/gtwizard_i/gt0_GTWIZARD_i/gtpe2_i/PLL1CLK
This is regarding a transceiver internal path between the GTPE2_COMMON cell and the GTPE2_CHANNEL cell.
Can you please confirm that this is not an issue? Just an erroneous warning? Is there a way to get rid of it?
hongh
It's device related information and for 7-series device it can be safely ignored.
For ultrascale/Utrascle+ device, the RX/TXoutclk of the GT_CHANNEL can be derived by the reference clock. (The intermediate clock pin will also be assigned a derived clock)
For 7 series, the RX/TXoutclk of the GT_CHANNEL has to be created directly on its clock output pin(Here define in IP), instead of being derived from the reference clock. So the input clock pin of GT_CHANNEL primitive having no clock created and it won't affect the behavior of the GT_CHANNEL.
hongh
Please refer to the below discussion:
https://forums.xilinx.com/t5/Timing-Analysis/quot-Register-Latch-pins-need-pulse-width-check-quot-on-GTP-in/m-p/973911#M16745
If you still have question, please attach your xci file.
11223344
I don't find this post helpful.
This issue has to do with internal IP constraints and I am not ready to modify the IP constraints without the full support of a Xilinx expert.
I am attaching the IP xci as you requested. I generated this IP with 2018.3, and when I open the associated example design and run implementation I get the same check timing pulse_width_clock warnings.
Thank you for your help.
11223344
hongh
11223344
Thank you for this information!
