allien
set_case_analysis with flip-flop
Hi All,
As mentioned in AR# 51464: Vivado - What scenarios are covered by set_case_analysis? (xilinx.com), set_case_analysis can be used with reset pin of a FF. I tried few example but didn't get expected result. Is this still supporting ?
viviany
Can you elaborate what you expected from using set_case_analysis with the reset pin of FF?
And how you used the set_case_analysis?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
allien
Hi Viviany,
I have a code like below
always @ (posedge clk_in or posedge reset) begin
  if (reset) begin
      state <= STATE_INIT;
  end
  else begin
    case (state)
      STATE_INIT : begin
          clk_gen <= 1'b0;
          state <= STATE_NEXT;
      end
      STATE_NEXT : begin
          clk_gen <= ~clk_gen;
      end
      default : begin
         clk_gen <= 1'b0;
      end
   endcase
  end
end
I have set reset as set_case_analysis 1. So I expect no timing analysis for the logic driven by clk_gen in timing summary report.
