synchronous clocks timing constraints ?
HI Friends,
I am using Kintex-7, i have generated 240M,60M,80M,48M clocks from MMCM. am getting setup issue on some path.
path are like :
1) source FF clock 60M and destination FF clock 240M
2) source FF clock 48M and destination FF clock 240M
3) source FF clock 80M and destination FF clock 240M
4) source FF clock 60M and destination FF clock 80M
Vivado considering requirement time some thing different than source clock time period. How to constraint these paths ?
Pls help me on this.
NOTE: Any help or suggestions are highly appreciated.
Thank You
S Sampath
Re: synchronous clocks timing constraints ?
Hi @ssampath,
Can you share the timing report by running tcl command report_timing_summary -file <filepath>/timingrpt.txt to evaluate?
hemangd
Don't forget to give kudos and accept it as solution if your issue gets resolved.
