the problem of offset in constraints
 when I set the offset in constraints, no matter how much I set the value is, at last, the timing analyzer will ignore the constraints, why? when set the "offset in" constraints, what need to consider more than "offset out" constaints?
thanks,
Jie
Re: the problem of offset in constraints
Two things: 1. the reference clock needs to come from an external clock input. 2. the clock used to register the input can be traced back to the reference clock input (via DCM, PLL, BUFG, etc).
Cheers,
Jim
Cheers,
Jim
You may also find this a useful reference:
http://www.xilinx.com/support/documentation/white_papers/wp237.pdf (What are OFFSET Constraints?)
bt
Does any information indicate why it is ignored? This is always caused by no timing group found.
