bahadirozk
timing and clock analyse
How do I get the timing and time information in Vivado for any design?20190531_015312.jpg20190531_015553.jpg
drjohnsmith
Vivado is not ISE,
Vivado runs till it meets your timing constraints and stops,
so you need to add timing constraints, then you will see if you meet or fail by how much.
bahadirozk
How do I do this on the ISE?
drjohnsmith
what you trying to do
bahadirozk
I design floaint point adder. I want to compare performance analyse
drjohnsmith
can we see your code
bahadirozk
I think this impossible. Becasue my codes are very tall.
yashp
If you are okay to share the code (as asked by other users) to review you don't need to copy paste the content you can attach the file.
Yash
P.S. I do not understand your requirement, can you please clarify it again what you are looking for?
