sunil_vnit
timing constraint problem
hello,
           while synthesizing my code i got some TIMING CONSTRAINT problem.i dont know how to overcome this problem.Is this error create any problem while i will dump this code in FPGA.plz give me any suggestion how to overcome this problem.
i have attach my synthesis summary also
-Sunil
sahana.barike
Reduce the frequency of the clock you are using for your design..
Sahana
sunil_vnit
i did not gave any clock frequency.simply  iahave written the code in xilinx ise 14.v and given a specified fpga board and synthesizing it.but still it gives time constarint problem.
-Sunil
bassman59
Historian
Historian
You need to set valid timing constraints for your design. This is FPGA 101 basic stuff.
htsvn
As
