Visitor laomar
ucf file to xdc file vivado syntax
im working on artix7 board and i want to attribute to each LUT an specific adress so i have an example of vhdl code and ucf file.
and i just want to know how i have to write this line ( INST "Chain[0].inst_lut" LOC=SLICE_X0Y60; ) in the xdc file in vivado.
vhdl code:
Library UNISIM;
use UNISIM.vcomponents.all;
entity lut is
port ( O_1: out std_logic ;
a: in std_logic ;
b: in std_logic ;
c: in std_logic ;
d: in std_logic ;
e: in std_logic ;
f: in std_logic
end entity ;
architecture behavior of lut is
--type S_TYPE is array (0 to 4) of std_logic;
signal S : std_logic_vector(14400 downto 0);
--signal inv_array : std_logic_vector(4 downto 0) ;
--attribute RLOC: string;
----attribute RLOC of S: signal is "X1Y0 X0Y0 X3Y0 X2Y0 X5Y0";
--attribute RLOC of S: signal is "X0Y0 X1Y0 X2Y0 X3Y0";
begin
S(0) <= a;
Chain: for i in 0 to 14400-1 generate
inst_lut : LUT6
generic map (
INIT => X"5555555555555555")
port map(
S(i+1), S(i), b, c, d, e, f
end generate Chain;
O_1 <= S(14400);
end architecture ;
example of line from UCF file:
INST "Chain[1].inst_lut" LOC=SLICE_X0Y60;
INST "Chain[2].inst_lut" LOC=SLICE_X0Y60;
INST "Chain[3].inst_lut" LOC=SLICE_X0Y60;
INST "Chain[4].inst_lut" LOC=SLICE_X1Y60;
INST "Chain[5].inst_lut" LOC=SLICE_X1Y60;
INST "Chain[6].inst_lut" LOC=SLICE_X1Y60;
INST "Chain[7].inst_lut" LOC=SLICE_X1Y60;
INST "Chain[8].inst_lut" LOC=SLICE_X2Y60;
Re: ucf file to xdc file vivado syntax
Hi, @laomar ,
Example for you:
set_property BEL D5LUT [get_cells {Chain[0].inst_lut}]
set_property LOC SLICE_X0Y60 [get_cells {Chain[0].inst_lut}]
It will be helpful for you to read "Converting UCF to XDC in the PlanAhead Tool" in UG911.
One thing you need to consider is that the cell name ("Chain[0].inst_lut" for example) given by Vivado Synthesis may not be the same as in ISE.
So you may need to check the cell names of those LUTs after running Synthesis in Vivado.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Visitor laomar
hello,
thanks for your answers.
I tried what you said and i put this in vhdl  code:
---------- lut134600.vhd ------------- /8 =16825 or/10 13460
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
Library UNISIM;
entity artix is
a: in std_logic ;
b: in std_logic ;
c: in std_logic ;
d: in std_logic ;
e: in std_logic ;
f: in std_logic
end artix;
architecture behavior of artix is
signal S : std_logic_vector(20800 downto 0);
begin
S(0) <= a;
Chain: for i in 0 to 20799 generate
inst_lut : LUT6
generic map (
port map(
S(i+1), S(i), b, c, d, e,f);
end generate Chain;
O_1 <= S(20800);
end behavior ;
and in the xdc file:
set_property BITSTREAM.SEU.ESSENTIALBITS yes [current_design]
set_property BITSTREAM.GENERAL.UNCONSTRAINEDPINS Allow [current_design]
set_property INIT_A 64'h5555555555555555 [get_cells LUT6 ]
set_property DONT_TOUCH true [get_cells -hier -filter {REF_NAME=~ LUT6}]
set_property BEL LUT6 [get_cells { Chain[0].inst_lut}]
set_property LOC=SLICE_X0Y0 Chain[0].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[1].inst_lut}]
set_property LOC=SLICE_X0Y0 Chain[1].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[2].inst_lut}]
set_property LOC=SLICE_X0Y0 Chain[2].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[3].inst_lut}]
set_property LOC=SLICE_X0Y0 Chain[3].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[4].inst_lut}]
set_property LOC=SLICE_X0Y1 Chain[4].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[5].inst_lut}]
set_property LOC=SLICE_X0Y1 Chain[5].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[6].inst_lut}]
set_property LOC=SLICE_X0Y1 Chain[6].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[7].inst_lut}]
set_property LOC=SLICE_X0Y1 Chain[7].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[8].inst_lut}]
set_property LOC=SLICE_X0Y2 Chain[8].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[9].inst_lut}]
set_property LOC=SLICE_X0Y2 Chain[9].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[10].inst_lut}]
set_property LOC=SLICE_X0Y2 Chain[10].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[11].inst_lut}]
set_property LOC=SLICE_X0Y2 Chain[11].inst_lut}]
etc ....
set_property BEL LUT6 [get_cells { Chain[20798].inst_lut}]
set_property LOC=SLICE_X163Y49 Chain[20798].inst_lut}]
set_property BEL LUT6 [get_cells { Chain[20799].inst_lut}]
set_property LOC=SLICE_X163Y49 Chain[20799].inst_lut}]
 the result:
Sythesis failed:
INFO: [Synth 8-638] synthesizing module 'artix' [C:/Users/ap93330/ARTIX/ARTIX.srcs/sources_1/new/ARTIX.vhd:20]
Parameter INIT bound to: 64'b0101010101010101010101010101010101010101010101010101010101010101
INFO: [Synth 8-113] binding component instance 'inst_lut' to cell 'LUT6' [C:/Users/ap93330/ARTIX/ARTIX.srcs/sources_1/new/ARTIX.vhd:26]
How to solve this?
thanks,
Hi, @laomar ,
What's error message you intend to resolve?
