Loking at a design in a kintex 7,
interfacing to a processor,
processor feeds out a 200 MHz clock with the data,
have some signals that change on each clock, so have constrained them normaly,
but have some signals that are present for two clocks,
so I can give them more time to settle
but still needs to be aligned to the clock,
how can I say this pin has two clock cycles to settle , do I need to look at mutli cycle paths ?
for refernace
all signals,
clk is 200 MHz,
data is valid 3ns after rising edge of clk and held for 1.5 ns
and as per the questoin , some signals are stable in for one clock , some for two.
and this is what I have for clock and the single clock wide signals
create_clock -period 5.000 -name clk_a -waveform {0.000 2.500} [get_ports CLK_pin]
set_input_delay -clock [get_clocks clk_a] -min 1.500 [get_ports {ADD[0]}]
set_input_delay -clock [get_clocks clk_a] -max 3.000 [get_ports {ADD[0]}]
