what are the different ways to provide clock ref to MMCM and PLL for 7 series FPGAs?
HI Friends,
Most of times i will use only IO Clk pads for MMCM/PLL ref clocks, But i read in UG472 as "MMCM/PLL has multiple resources for ref clock".
Any help or suggestions are highly appreciated.
Thank You
S Sampath
-Sampath
In the UG you can look up the details of the primtive inputs/outputs. On page 80 for example: https://www.xilinx.com/support/documentation/user_guides/ug472_7Series_Clocking.pdf
CLKIN1 – Primary Reference Clock Input:
CLKIN1 can be driven by SRCC or MRCC I/O directly within the same clock region, SRCC or MRCC I/O through the CMT backbone in a vertically adjacent clock region, BUFG, BUFR, BUFH, interconnect (not recommended), or directly by a high-speed serial transceiver. When the clock input is coming from another CMT block for cascading CMT functions, only CLKOUT[0:3] can be used.
CLKIN2 – Secondary Clock Input:
CLKIN2 is a secondary clock input that is used to dynamically switch the MMCM/PLL reference clock. CLKIN2 can be driven by SRCC or MRCC I/O directly within the same clock region, SRCC or MRCC I/O through the CMT backbone in a vertically adjacent clock region, BUFG, BUFR, BUFH, interconnect (not recommended), or directly by a high-speed serial transceiver
You can see all the ways that you can drive the pin other then an IO port.
