microchip_zhang
when using axi vdma ,the timing fail ?
please refer to the attachment ,how to impove the timing of the vdma below in the figure, can impove the timeing via inserting reg in the combinatorial logic  like axi interconnect IP ? or the logic out of the vdma ip cause the failure
florentw
HI @microchip_zhang
In the latest version of the AXI VDMA there is no scatter gather so you will not face this timing issue. So I suggest you move to a newer vivado version.
There is no more support for the version you are using
Florent
florentw
Hi @microchip_zhang
There is not much detail to help. How the VDMA is connected? What clock is used? Are you using the same clock for all the interfaces?
Did you see AR#71984?
Florent
microchip_zhang
I think the *.xdc file of the vdma is functional, according to the figure shown below, and the the vivado version I am using is 2014.4
microchip_zhang
now I have edit the self-defined IP , but now the timing fail is in axi interconnect , I have add the register slice using the IP wizard of the axi interconnect,but still timing can not be satisfied ,the figure shown  below is the timing report of synthesis
microchip_zhang
the timing report of implementation has warning
microchip_zhang
axi VDMA is connected to axi interconnect1 directly,  vdma  and axi interconnect1 all use FCLK0 which outputs by processing system of zynq.
what is the  reason of  timing fail ? besause the self-defined IP  or there are other reasons ?
all the IP including self-defined IP  , axi interconnect, and  axi vdma  work using the FCLK0 which outputs by processing system of zynq, the fequency is 200mhz,
florentw
HI @microchip_zhang
Florent
