Voyager
Voyager
why clock is connected to data pin of flop ?
Hi Friends,
I am not understanding schematic view vs my code while analysing the hold path. clock net connected to data pin of the flop. Can any one help on this?
NOTE: Any help or suggestions are highly appreciated.
-Sampath
Re: why clock is connected to data pin of flop ?
Hi @ssampath ,
Can you post your full code to investigate?
hemangd
Voyager
Voyager
how can i send securely ?
-Sampath
We need to know how i_adc_ext_trig is coded.
And how are CLR and CE connected for the FDCE in the netlist?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Voyager
Voyager
-Sampath
Which net in the image above is "adc_reset_n"?
Can you post the code that generates "i_adc_ext_trig"?
We have an EZMOVE system that you can use to send files securely, can you send me your source files with EZMOVE? Make sure that those files can be used to reproduce the issue at my end.
-vivian
