wrong timing requirement 0.000 while 1.500 expected
With an implemented design open, I have my source synchronous input DDR interface constrained for 142MHz:
If I set 333MHz, instead, I get the following:
In the column "Requirement" it says 0.000, I would have expected 1.500.
constraints where defined as
create_clock -name HDMI_RX_CLK_P -period 3.0 [get_ports HDMI_RX_CLK_P]
set_input_delay -clock HDMI_RX_CLK_P -max [expr 1.6] [get_ports HDMI_RX_P*];
set_input_delay -clock HDMI_RX_CLK_P -min [expr 1.4] [get_ports HDMI_RX_P*];
set_input_delay -clock HDMI_RX_CLK_P -max [expr 1.6] [get_ports HDMI_RX_P*] -clock_fall -add_delay;
set_input_delay -clock HDMI_RX_CLK_P -min [expr 1.4] [get_ports HDMI_RX_P*] -clock_fall -add_delay;
why is it constrained with 0.000 ns?
thakurr
Hi @theultimatesource
To my understanding for DDR interface with 333 MHz clock, the set up requirement is expected to be 1.5 ns while hold requirement is 0 ns. The hold requirement is calculated one clock edge before to the set up. For hold, data is launched and captured on same clock edge for ideal scenario.
Rohit
thakurr
Rohit
