Visitor mrwang
GTwizard example for VCU118 QSFP with linerate above 28.125-Gbps
Hi, all.
   I am currently working on VCU118 board.  According to "pg182-gtwizard-ultrascale.pdf", I create an GTwizard core and generate the example design. However,when the the board working with line rate above 28.125-Gbps, the eye scan looks so bad. So, where can I get an example design for line rate above 28.125-Gbps?
Sincerely.
Advisor evgenis1
Advisor
Re: GTwizard example for VCU118 QSFP with linerate above 28.125-Gbps
Hi @mrwang ,
VCU118 development board uses ES (engineering sample) FPGA. It has lower transceiver line rate than production FPGA. That might explain poor eye scan results you're getting.
Evgeni
