Issue about IDELAY3 drivers
[DRC REQP-1741] IDELAYE3 drives invalid load: IDELAYE3 i_if_a/i_adc_clk/i_rx_data_idelay DATAOUT pin (net: i_if_a/i_adc_clk/clk_idelay_s) may not drive a BUFG*.
module ad_data_clk
  input               rst,
  output              locked,
  input               delay_clk,
  input               clk_in_p,
  input               clk_in_n,
  input [8:0]         delay_value,
  output              clk_ibufg_s
  wire                clk_ibuf_s;
  wire                clk_idelay_s;
  // defaults
  assign locked = 1'b1;
  IBUFGDS i_rx_clk_ibuf (
    .I (clk_in_p),
    .IB (clk_in_n),
    .O (clk_ibuf_s));
   BUFG i_clk_gbuf (
     .I (clk_idelay_s),
     .O (clk_ibufg_s));
   // (* IODELAY_GROUP = IODELAY_GROUP *)
     IDELAYE3 #(
      .CASCADE("NONE"),          // Cascade setting (MASTER, NONE, SLAVE_END, SLAVE_MIDDLE)
      .DELAY_FORMAT("COUNT"),     // Units of the DELAY_VALUE (COUNT, TIME)
      .DELAY_SRC("IDATAIN"),     // Delay input (DATAIN, IDATAIN)
      .DELAY_TYPE("VAR_LOAD"),      // Set the type of tap delay line (FIXED, VARIABLE, VAR_LOAD)
      .DELAY_VALUE(0),           // Input delay value setting
      .IS_CLK_INVERTED(1'b0),    // Optional inversion for CLK
      .IS_RST_INVERTED(1'b0),    // Optional inversion for RST
      .REFCLK_FREQUENCY(200.0),  // IDELAYCTRL clock input frequency in MHz (200.0-2667.0)
      .SIM_DEVICE("ULTRASCALE_PLUS")//, // Set the device version (ULTRASCALE, ULTRASCALE_PLUS, ULTRASCALE_PLUS_ES1,
                                 // ULTRASCALE_PLUS_ES2)
      // .UPDATE_MODE("ASYNC")      // Determines when updates to the delay will take effect (ASYNC, MANUAL, SYNC)
   i_rx_data_idelay (
      .CASC_OUT(),       // 1-bit output: Cascade delay output to ODELAY input cascade
      .CNTVALUEOUT(), // 9-bit output: Counter value output
      .DATAOUT(clk_idelay_s),         // 1-bit output: Delayed data output
      .CASC_IN(1'b0),         // 1-bit input: Cascade delay input from slave ODELAY CASCADE_OUT
      .CASC_RETURN(1'b0), // 1-bit input: Cascade delay returning from slave ODELAY DATAOUT
      .CE(1'b0),                   // 1-bit input: Active high enable increment/decrement input
      .CLK(delay_clk),                 // 1-bit input: Clock input
      .CNTVALUEIN(delay_value),   // 9-bit input: Counter value input
      .DATAIN(1'b0),           // 1-bit input: Data input from the logic
      .EN_VTC(1'b0),           // 1-bit input: Keep delay constant over VT
      .IDATAIN(clk_ibuf_s),         // 1-bit input: Data input from the IOBUF
      .INC(1'b0),                 // 1-bit input: Increment / Decrement tap delay input
      .LOAD(1'b1),               // 1-bit input: Load DELAY_VALUE input
      .RST(1'b0)                  // 1-bit input: Asynchronous Reset to the DELAY_VALUE
endmodule
Re: Issue about IDELAY3 drivers
Hi @kuailelinghun
Looking at the shared RTL, your objective here is the delay the clock. But IDELAYE3 is not used for Clock Delaying.
 https://www.xilinx.com/support/documentation/user_guides/ug571-ultrascale-selectio.pdf   (page 167).
Please reply if you have any further queries, Give Kudos and accept as solution if you get one
