Visitor yuval_yehiam
MMCM outputs clock edge alignment
For an MMCM that is configured with feedback and safe mode, we are generating a clk_divide_by_4 and a clk_divide_by_5 outputs.   In the simulation we see that phase of the outputs does not align on the first clock outputs, but after some random number of clocks. Is there a way to configure the MMCM so the first (or the known Nth) outputs clocks will be phase align?
Historian
Historian
Re: MMCM outputs clock edge alignment
What does the "first" edge mean? In simulation there is a defined "beginning", but in reality, the starting up of an MMCM is an analog process - there isn't really a concept of the "first" edge.
So the answer is "you can't".
With your configuration you know that there will be one edge that is aligned between the clocks - every 5th clock of the divide_by_4 and every 4th clock of the divide_by_5 (every 20th clock of the base clock) - but which one it is is harder to figure out.
First, generally, you don't need to know this...
But if you do, I am not sure it is possible with just these clocks - you may also need a clock that represents the common divider - a divide by 20 clock.
The reality is that the MMCM does synchronize all its dividers after it has achieved lock - so the rising edge of the divide_by_20 clock will be the edge in which the divide_by_4 and divide_by_5 align. It is fairly easy to find the phase of a faster clock with respect to a slower clock - take a look at this post for finding the phase of a clock with respect to a slower clock.  While the post is old and talks about older technologies, the same idea can be used. Compare your divide_by_4 to your divide_by_20, and your divide_by_5 to your divide_by_20 - each will give you the "first" phase, you really want the "last" phase (since that is the clock period before the edges align) so you need a simple counter to get to the last one.
Avrum
Thanks Avrum,
That was very clear.
Yuval Yehiam
