Visitor vttmw93
Pull-up resistors on Zynq MPSoC SPI interface MISO, MOSI signals
I am using the xtp427 ultrascale-plus schematic review checklist to review my Zynq US+MPSoC schematic.  The checklist says to place 2.0kohm pull-up resistors on the SPI MISO and MOSI signals near the SPI device (with no other explanation).  I cannot find any other Xilinx documents that recommend a pull-up on MISO, MOSI.  For example, UG583 pg 178 recommends pull-ups on SPI SS pins, but no mention of pullups on MISO, MOSI.  We are interfacing to a Cypress QSPI Flash (S25FL256) which also has no recommendation for pull-ups on MISO, MOSI.  Are these pull-ups really required?  And if so why?
Thanks, Ted
Re: Pull-up resistors on Zynq MPSoC SPI interface MISO, MOSI signals
Oddities like this recommendation are generally the response to unexpected operation in the absence of the recommended action. Since the SPI interface can be operated as a master or a slave, it is likely that the circuitry can get confused if the MOSI and/or MISO lines are not pulled high at some point during system operation.
If you wait long enough, you might get a more-official response like this:
     https://forums.xilinx.com/t5/7-Series-FPGAs/PS-MIO-SPI-pull-ups/m-p/902053
-Joe G.
-Joe G.
Visitor vttmw93
Thank you very much Joe.  I will include the resistors in my design.
-Ted
