RFSOC initialization question
My question is about initialization of RF ADC in ZCU111 board.
It is written in pg269 on page 32
"The IP core also handles the configuration and powerup of the data converters. This ensures that the settings specified in the Vivado IDE are applied to the RF-ADCs and RF-DACs immediately after the PL configuration completes."
When I open example design simulation,
1) It first writes simulation speed up registers.
2) write restart state register and restart power on state machine registers for all tiles.
3) Read "restart state registers" and "current state registers" for all tiles until they reach a specific state (powered up).
So these steps are fine as we waited for ADCs and DACs to power up. Then example design write all configuration data to ADCs and DAC tiles like mixer config, mixer mode etc.
My question is: In our custom design, should we just wait for power up (till point 3 above) and start reading ADC values? Or should we program all configuration data too?
If we follow the text in blue, What I get is, that IP will send all configuration data itself (according to what we programmed in IP config window). If that is true, in example design, where is this data going automatically to IP? All I see is config data is also sent to IP by testbench.
Re: RFSOC initialization question
Is there anyone who can answer this query? or aren't there many people at xilinx who can answer queries on these advance devices?
@klumsde : You seem to answer queries on RFSOCs. Will you or someone else?
Is this such a difficult question for people at xilinx to answer? 6 days..no answer
In hardware you get the IP config loaded with the bitfile, there is no need to intervene and change settings unless you need to.
The Example design has a folder called Imports
In here you will find
demo_tb_axi4l_nano_seq.v
In here you can see it turning off the mixer and turning off Chopping in the ADC since the sim only makes a check that a triangle wave is increasing or decreasing in magnitude and having the mixer on makes no sense because the signal is real and not complex. Chopping won't make an appreciable difference to the output of the ADC and the only thing they will do is add run time.
If you are doing something more elaborate then you can go in and remove these writes so that you get the IP as is with the mixer enabled etc.
Keith
Thanks Keith (@klumsde ) for such a fast reply :S
I got it that in hardware, we dont need to program anything. Just we need to read current status register of ADCs until they are all giving value  "2" ?
In simulation (and hardware), after power up (current state registers giving 2 on reading), do we need to just give data at analog inputs and it will come on AXI channels?
After this you can consider the output on the ADC AXI stream valid.
I am reading for current state register for value 2 because in example design, When it reads 4 ADC tile current state registers as 2, it takes as configuration completed.
In custom design, upon your suggestion, I am reading values of current state registers of 4 ADC tiles in 4 registers to reach till value F but design is run for 420 us (in more than an hour) and still it is stuck on value 7 (which is clock configuration step). It is not reaching next state.
Do I need to run sim for long or am I doing something wrong that it's not moving forward?
Hi @a4speaker
I guess at this point I am a little confused about what you are asking.
A DAC tile in HW can take about 30ms to start and an ADC can take about 40ms.
In the example design the simulation is sped up using the speedup register and also be doing writes to the Blocks to turn off mixers and some ADC calibration functionality that will not impact a simulation like the example where you are only sampling a ramp and determining if it is rising and falling.
If I run the simulation again I see that it sets the speedup waits for the tiles to reach an end state of F or B
T= 0: Xilinx RF AMS Demo Testbench.
T= 335100: Delay of 40 cycles requested.
T= 755100: Accelerate SIM startup
T= 855100 D= 855100 (ps): AXI WRITE: AxiAddr=0x00004100, Decode H= 2 L= 64, Data=0x00000001 DCC0_SUPPLY_DETECTION_TIMER_ADDR
T= 975100 D= 120000 (ps): AXI WRITE: AxiAddr=0x00008100, Decode H= 4 L= 64, Data=0x00000001 DCC1_SUPPLY_DETECTION_TIMER_ADDR
xsim: Time (s): cpu = 00:00:19 ; elapsed = 00:00:14 . Memory (MB): peak = 10158.633 ; gain = 0.000 ; free physical = 19026 ; free virtual = 212203
INFO: [USF-XSim-96] XSim completed. Design snapshot 'demo_tb_behav' loaded.
INFO: [USF-XSim-97] XSim simulation ran for 1000ns
launch_simulation: Time (s): cpu = 00:01:01 ; elapsed = 00:01:38 . Memory (MB): peak = 10158.633 ; gain = 0.000 ; free physical = 19026 ; free virtual = 212203
run 500 ms
T= 1095100 D= 120000 (ps): AXI WRITE: AxiAddr=0x0000c100, Decode H= 6 L= 64, Data=0x00000001 DCC2_SUPPLY_DETECTION_TIMER_ADDR
T= 1215100 D= 120000 (ps): AXI WRITE: AxiAddr=0x00010100, Decode H= 8 L= 64, Data=0x00000001 DCC3_SUPPLY_DETECTION_TIMER_ADDR
T= 1335100 D= 120000 (ps): AXI WRITE: AxiAddr=0x00014100, Decode H=10 L= 64, Data=0x00000001 ACC0_SUPPLY_DETECTION_TIMER_ADDR
T= 1455100 D= 120000 (ps): AXI WRITE: AxiAddr=0x00018100, Decode H=12 L= 64, Data=0x00000001 ACC1_SUPPLY_DETECTION_TIMER_ADDR
T= 1575100 D= 120000 (ps): AXI WRITE: AxiAddr=0x0001c100, Decode H=14 L= 64, Data=0x00000001 ACC2_SUPPLY_DETECTION_TIMER_ADDR
T= 1695100 D= 120000 (ps): AXI WRITE: AxiAddr=0x00020100, Decode H=16 L= 64, Data=0x00000001 ACC3_SUPPLY_DETECTION_TIMER_ADDR
T= 1715100: Disable the ADC cal to reduce simulation time.
T= 158405100: Wait for data........
T= 163545100: Tile 00 has reached its end state of 0000000f
T= 166125100: Tile 01 has reached its end state of 0000000f
T= 167165100: Tile 05 has reached its end state of 0000000b
T= 167425100: Tile 06 has reached its end state of 0000000b
T= 167685100: Tile 07 has reached its end state of 0000000b
T= 169225100: Tile 04 has reached its end state of 0000000b
So you are not using the speedup?
You are not changing at least the ADC cal stuff.
I don't know why you are surpised that the tile is taking a long time to start in this case.
Keith
I am writing 1 to ADC speed up registers (not DAC as I am not using dacs). I am following steps in example design.
My question is simple. I am waiting for ADC tiles(not DAC tiles) to give value F in current state registers but they are stuck in state 7 and running simulation for hours, they are stuck in state 7 and not changing value.
Example design sim is also run for a long time but some tiles give value F quite quickly but some tiles are stuck at current state 7. I can't see output on ADC axi channels .
It won't be easy to debug this without me seeing your test bench.
Can you send me a PM with your email address so I can get you to share the files
I am not doing much in testbench. Just giving clocks from test bench. I am Sending AXI reads and writes in firmware and not testbench. Here is the sequence of AXI reads writes as copied from example design. (not sending DAC addresses as I am not using DACs).
WRITE : addr: 14100,  data : 1    //sim speed reg ADC tile 0
WRITE : addr: 18100,  data : 1    //sim speed reg ADC tile 1
WRITE : addr: 1C100,  data : 1   //sim speed reg ADC tile 2
WRITE : addr: 20100,  data : 1    // sim speed reg ADC tile 3
WRITE : addr: 14008,  data : b    //ADC tile 0 restart state register
WRITE : addr: 14004,  data : 1    //ADC tile 0 restart power on state machine register
WRITE : addr: 18008,  data : b    //ADC tile 1 restart state register
WRITE : addr: 18004,  data : 1    //ADC tile 1 restart power on state machine register
WRITE : addr: 1C008,  data : b    //ADC tile 2 restart state register
WRITE : addr: 1C004,  data : 1    //ADC tile 2 restart power on state machine register
WRITE : addr: 20008,  data : b    //ADC tile 3 restart state register
WRITE : addr: 20004,  data : 1    //ADC tile 3 restart power on state machine register
Then reading restart state register and current state registers until current state register reads value F
READ  :  addr 14008   // ADC tile 0 restart state register
READ  :  addr 1400C   // ADC tile 0 current state register
READ  :  addr 18008   // ADC tile 1 restart state register
READ  :  addr 1800C   // ADC tile 1 current state register
READ  :  addr 1C008   // ADC tile 2 restart state register
READ  :  addr 1C00C   // ADC tile 2 current state register
READ  :  addr 20008   // ADC tile 3 restart state register
READ  :  addr 2000C   // ADC tile 3 current state register
The current state register value for all ADC tiles is stuck at 7 and not moving forward. Simulation is run for 500 us.
Do you get now?
Hi @a4speaker
i've been playing with your simulation and I can reproduce what you see.
I am not sure why this is occurring.
I will keep working on this. You don't have to private message me every day for an update. from now we will deal with this via this thread.
Keith.
Did this "play" give you any clue or should I wait indefinitely?
Upon analyzing usp_rf_data_converter_0_por_fsm module, I found out that after some time the status FSM makes pll_error signal high. Can you tell why is this error signal asserted?
I am looking at your test bench and design.
you have the IP set up with the tile PLL enabled and a 250MHz reference clock selected.
then at the level above in the test bench you have created full rate ADC clocks
always
#0.125 // 4000 mhz clock
begin
adc0_clk_clk_p = ! adc0_clk_clk_p;
adc0_clk_clk_n = ! adc0_clk_clk_n;
adc2_clk_clk_p = ! adc2_clk_clk_p;
adc2_clk_clk_n = ! adc2_clk_clk_n;
end
always
#0.131575 // 3800 mhz clock
begin
adc1_clk_clk_p = ! adc1_clk_clk_p;
adc1_clk_clk_n = ! adc1_clk_clk_n;
adc3_clk_clk_p = ! adc3_clk_clk_p;
adc3_clk_clk_n = ! adc3_clk_clk_n;
end
So I am not surprised it is not locking the PLL and you are stuck at step 7
Re-running with a valid input clock, show that it progresses past the clock configuration stage. rfdc_startup_sim.JPG
There was confusion reading adc[3:0]_clk_p/n description in table 47 of PG269. It is now understood that if PLL is enabled, we need to give reference clock on pins rather than sampling clock. PLL will generate sampling clock. This solved my issue.
The final questions on this thread are:
Question 1: restart state registers of ADC are not moving beyond "b" value. Is this the final stage in simulation? (I am asking this as it is written is power up sequence that "done" state is "F"). As you can see in waveform attached, the value of por_sm_state  in rf_data_converter_por_fsm.sv is stable at "14" which is "finish" state.
Question 2: As you can see in waveform attached, m00_axis_tvalid signal is asserted and data is coming on m00_axis_tdata. Is this valid ADC data? I am asking this as nothing is given on ADC analog input and data is coming on output. Is this some modeled noise?
I'll need to look into this question on the tile state question in my mind it should get to 0xF like i see in the hardware.
Unless you tell it to stop at a given state it should go all the way to the end.
When the ADC tile starts valid should go high and data will start to stream out. I'd imagine the simulation model will have some error built in so for 0 Input you will get 0+some offset at least.
@klumsde : I will wait for your reply about done state in simulation.
