SPI ZYNQ Ultrascale + Configuration
I'm using the custom board attached and I need to program a clock chip (LMx2592) whoes SPI port is connected to the FPGA bank 87. These pins are not broken out to a header so I need to configure the chip through the FPGA. Is it possible to map inside the fpga these SPI pins to pins in the mezzanie connector so that I can connect the mezzanie connections to my TI SPI programming module. Unfortunately, all other gpio pins are not broken out on this board so this seems the only option.
