Visitor mnanoop2014
Unable to detect custom IP in linux ZCU102
I created a custom AXI4 IP that is connected to ZynqMP through an AXI interconnect. I am able to run bare metal applications perfectly (using xilinx-provided header files), able to read and write to registers in it and also verify operations of the IP.
However, now I want to be able to do the same through an app running in linux.
I am able to boot up linux. I have verified the device tree entry of the custom IP in <peta_home>/components/plnx_workspace/device-tree/device-tree-generation/pl.dtsi in which I only changed the compatible field to point to my custom kernel driver module, say "mm,redefine".
The driver module is created using petalinux-create -t modules command and is enabled in the petlainux-config -c rootfs. The module builds successfully without errors. Created an application using petalinux-create -t apps and also enabled it. It builds successfully too. Which just writes to some registers and reads registers (results) in the custom IP.
And then petalinux-build it successfully.
However, when I program FPGA using petalinux-boot --jtag --fpga --bitstream <my.bit file>
And then boot linux using petalinux-boot -jtag --u-boot,
I don't see my application when I type the name of the application. And I don't see my device in /dev. I don't see my driver module in /sys/class.
Is there any reference for building linux apps and custom drivers for running applications involving custom IPs?
TIA
