Observer jessexi
power of XCKU115 board is short circuit
Hi xilinx
   1.8v bank voltage of XCKU115 board is short circuit.XCKU115 was taken down from the PCB.How to test XCKU115 is ok?
Community Manager
Community Manager
回复: power of XCKU115 board is short circuit
If you get it from our distributor, you may contact with them and start an RMA process to check if the chip is broken.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Observer jessexi
Thanks a lot
