取消
显示结果
搜索替代
您的意思是:
655 次查看
注册日期: ‎02-01-2018
请教有关methodology中的警告
在ultrafast设计法中,根据report_failfast报告中常常有关TIMING-6和TIMING-7的REVIEW,然后从report_methodology中查看详细信息,结果如下。
TIMING-6
The clocks CLK_OUT1_1 and rgmii_rxc are related (timed together) but they have no common primary clock. The design could fail in hardware. To find a timing path between these clocks, run the following command: report_timing -from [get_clocks CLK_OUT1_1] -to [get_clocks rgmii_rxc]
TIMING-7
The clocks CLK_OUT1_1 and rgmii_rxc are related (timed together) but they have no common node. The design could fail in hardware. To find a timing path between these clocks, run the following command: report_timing -from [get_clocks CLK_OUT1_1] -to [get_clocks rgmii_rxc]
不是很能理解导致这两条警告的原因,求教,谢谢~
0 项奖励
1 条回复1
548 次查看
注册日期: ‎07-17-2008
回复: 请教有关methodology中的警告
请看一下UG906,第286页,附录A中对于这两个check的描述。
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug906-vivado-design-analysis.pdf
0 项奖励
