3 DNA resources available
When trying to use to instantiate "DNA_PORTE2" primitive, I can see that there is 3 "DNA_PORTE2" primitives available on VU9P FPGA:
8. CONFIGURATION
| Site Type          | Used | Fixed | Available | Util%  |
| DNA_PORTE2 |       1 |         0 |     3       | 33.33  |
So I try to implement 3 "DNA_PORTE2" on a test design and I discovered that the 3 instances point on the same location (information from the graphical view on Vivado 2017.1).
Can you confirm that the DNA is unique by device and that the 3 primitives point to the same DNA unique id ?
Best
Hi, @jeydoux ,
Each device contains a single unique, 96-bit, embedded, device identifier (device DNA).
FPGA designs can access the DNA internally through a Device DNA Access Port, there is one DNA_PORTE2 in one SLR.
Since VU9P has 3 SLRs, there are 3 DNA_PORTE2 primitives in the device.
The available value in Util report is correct.
DNA_PORTE2 is only the channel to visit DNA. It's expected to have same DNA unique id.
Hi, @jeydoux ,
Hi @hongh,
Thanks for the clear answer, it was our hypothesis.
