mufeed029
AC Timing Parameters of clock input to GC pins of XCZU28DR
Hi Team,
I am using XCZU28DR RFSoC, and planing to give differential clock input of 156.25MHz to GC pins of bank 65. Can anyone help me to find out the ac parameters ( phase noise, jitter, etc.) of this input reference clocks.
pthakare
Hi @mufeed029
There are no explicit specifications for Global clock inputs,  four GC pin pairs in each bank  have direct access to the global clock buffers, MMCMs, and PLLs that are in the CMT adjacent to the same I/O bank.
The global clock buffer dont have any requirement on input clock jitter , it wil pass the same clock to output plus some additional jitter if internal supply powering these buffers are noisy.
MMCM and PLL have restriction on Maximum input clock jitter , it should be  < 20% of clock input period or 1 ns Max , othewise MMCM will not lock.
The Global clock buffers, MMCM and PLL switching characteristics are given in same datsheet.
pthakare
Hi @mufeed029
Please refer to "RF Converters Clocking Characteristics"  in datasheet page 102.
https://www.xilinx.com/support/documentation/data_sheets/ds926-zynq-ultrascale-plus-rfsoc.pdf
mufeed029
Hi @pthakare
Thanks for your reply.
The page number 102 in ds926 describing input clock specification of ADC and DAC sections.
I need input clock specifications of GC pins.
pthakare
Hi @mufeed029
