BITSLICE_CONTROL instance error for ultrascale+ VU9P
ERROR: [DRC 23-20] Rule violation (PDRC-198) Serial_mode_bitslice_0_connected - SERIAL Mode : The SERIAL mode nibble at BITSLICE_CONTROL instance gmac_wrapper/core_wrapper_i/inst/pcs_pma_block_i/gen_io_logic/BaseX_Byte_I_Rx_Nibble/Gen_1.Nibble_I_BitsliceCntrl must have an RX_BITSLICE or RXTX_BITSLICE connected to bitslice position 0 with attribute DATA_TYPE set to 'SERIAL', see Select IO Userguide UG571 for more information.
Re: BITSLICE_CONTROL instance error for ultrascale+ VU9P
I am having the same issue, any update on this?
Reza
That will go away is you chose DIFF PAIR 1.
Reza
I get similar error. How did you resolve this issue? What is the reason for that? Thanks!
[Place 30-689] Failed to place BITSLICE_CONTROL cell TargetBoard_BIST_i/axi_ethernet_0/inst/pcs_pma/inst/pcs_pma_block_i/gen_io_logic/BaseX_Byte_I_Tx_Nibble/Gen_1.Nibble_I_BitsliceCntrl on site BITSLICE_CONTROL_X1Y50 because Instance TargetBoard_BIST_i/axi_ethernet_0/inst/pcs_pma/inst/pcs_pma_block_i/gen_io_logic/BaseX_Byte_I_Tx_Nibble/Gen_1.Nibble_I_BitsliceCntrl can not be placed in CONTROL of site BITSLICE_CONTROL_X1Y50 because the bel is occupied by TargetBoard_BIST_i/axi_ethernet_0/inst/pcs_pma/inst/pcs_pma_block_i/gen_io_logic/BaseX_Byte_I_Rx_Nibble/Gen_1.Nibble_I_BitsliceCntrl(port:). This could be caused by bel constraint conflict. Please check if the cell is used correctly in the design.
Hi @astrome
Are you modifying any location constraints default in the IP?
Dear @pthakare
I  haven't medled with the IP.  I have used the same/usual constraints.
