Baremetal DisplayPort example for UltraScale+ MPSoC
The topic says it: I am looking for a low level setup to use the DisplayPort displaying a simple frame buffer (i.e. without the use of Mali).
Cheers,
42Bastian
Re: Baremetal DisplayPort example for UltraScale+ MPSoC
Hi @42bs,
I don't think there is any bare-metal application using the DisplayPort hard IP.
The current solution is to use a linux OS
Florent
Florent
