Booting from a SD card in ZCU104
Can someone properly explain how to boot from a SD card in Xilinx ZCU104? I followed the documentation (https://www.xilinx.com/support/documentation/boards_and_kits/zcu104/ug1267-zcu104-eval-bd.pdf) and set the switches(1110) as below:
IMG_20191003_162417.jpgDIP switches
IMG_20191003_162413.jpgSW6
I am not sure if this is the correct way to set them to boot. The led beside the switches is always red. Regardless I tried to see any messages coming up while booting from a serial console. In my case I'm using gtkterm. I opened several windows for all the tty with a baud rate of 115200. But nothing shows up in the serial console as well. I have formatted the SD card as FAT32 and copied the BOOT.bin and the image.ub file from my petalinux project to the sd card.
I am confused as to why this is happening and if I'm doing something wrong. If someone can help with this situation it'll be really great. Thank you.
Tags (3)
Observer kiran1490
Re: Booting from a SD card in ZCU104
The configuration for SD BOOT for ZCU104 is wrong in your case .  Switch SW6 configuration switch 1 should be in ON condition and Switch 4 Should be in OFF condition. Basically you have interchange the positions of switch 1 and switch 4 as shown in below diagram.
Observer kiran1490
@kiran1490 I tried your configuration but I get the same results. Red LED and nothing in the serial console. I have connected the FPGA to the pc (via UART) and to a power supply. Should my PC have some mandatory requirements that needs to be met before I can see anything in the console for ZCU104? Also what should be the correct configuration for the DIP switches?
Observer kiran1490
There is no need to configure SW17 DIP switches for the mode of booting. Only you have to configure SW6 switches . Take a glance at ZCU104 Userguide for SW6 and SW17 switches and configure only SW6 switches according to my previous reply. If you are using windows try teratorm serial console and if you are using linux try gtkterm and set the USB0 and Baudrate 115200 as confiurations in serial console.
