Bug in IDELAYE3 simualtion model
Hi all,
I found a problem in IDELAYE3 VHDL simulation model (2018.1 and 2018.3). When using TIME delay format, number of taps is calculated by dividing specified time with 5 ps.
function Idelaye3_InitDelayCount(
DelayFormat : in string;
DelayValue : in integer
) return integer is
begin
if(DelayFormat = "TIME") then
return integer(real(DelayValue)/5.0);
else return integer(DelayValue);
end if;
end;
The problem is in fact that Ultrascale+ architecture specifies average delay per tap to 4 ps:
elsif ((SIM_DEVICE = "ULTRASCALE_PLUS") or (SIM_DEVICE = "ULTRASCALE_PLUS_ES1") or (SIM_DEVICE = "ULTRASCALE_PLUS_ES2")) then
PER_BIT_FINE_DELAY <= 4;
PER_BIT_MEDIUM_DELAY <= 32;
INTRINSIC_FINE_DELAY <= 60 ps;
INTRINSIC_MEDIUM_DELAY <= 32 ps;
IDATAIN_INTRINSIC_DELAY <= 15 ps;
DATAIN_INTRINSIC_DELAY <= 32 ps;
CASC_IN_INTRINSIC_DELAY <= 32 ps;
CASC_RET_INTRINSIC_DELAY <= 32 ps;
DATA_OUT_INTRINSIC_DELAY <= 20 ps;
CASC_OUT_INTRINSIC_DELAY <= 45 ps;
end if;
This causes the actual configurable delay to be 80% of the required one.
Best regards
Srdjan
Community Manager
Community Manager
Re: Bug in IDELAYE3 simualtion model
Hi @srdjan.opacic
Thank you for including such good detail in the post. I have filed a Change Request against the simulation Model.
Sandy
Sandy
Community Manager
Community Manager
Hi @srdjan.opacic
Sandy
Sandy
