f.gavioli
Calculate duty cycle of an input PWM signal
I would like to implement a PWM signal reader in FPGA PL.
Specifically, the signal comes out via a pin from a RC receiver, and gets connected to an ultra96 board via the low speed gpio header.
I am working with a 100Hz signal with a variable duty cycle from 10% to 20%.
Problem is, i would like to read the signal and calculate the duty cycle from the PL, and then pass it to the PS via AXI.
Is there any ready-to-use IP to achieve this? If the answer is no, could anyone point me to the right direction to implement it in HLS?
Federico
bruce_karaffa
You need to make a couple counters.  One to count a 10 mS period (1/100Hz), one to count up when the incoming signal is high.  The value of the second counter is your duty cycle if you put the decimal place in the right spot.
