npalmer
Can I access the PS QSPI Pins from the PL?
This might be a stupid question, but is it possible to access a QSPI device that is connected to the Zynq UltraScale+ PS QSPI pins directly from the PL?  I am working on a test design and have only a MicroBlaze (no instance of the Zynq in the Vivado design) and I would like to access the QSPI FLASH from the MicroBlaze.  Is this possible? Vivado will not let me connect an AXI Quad SPI IP to the pins.
muzaffer
Here is an example for talking to uart from microblaze:http://www.xilinx.com/support/answers/50869.html
Alas it's for zynq soc but the basic idea should apply.
muzaffer
@npalmer No alas PL can't access to PS pins so you can't have a PL IP use MIO pins. Luckily you can control the PS controllers from PL so make a small PL axi master to talk to the qspi controller in PS.
npalmer
@muzaffer Can you point me to an example design that does something similar?  I am using the zcu102 development board.
I assume that I have to drop a Zynq IP Block in the Vivado design and configure the QSPI controller there, then connect the MicroBlaze to the Zynq IP over the AXI master you mentioned?
muzaffer
