Visitor qubits1
Can I use SPI config pins as user IO after configuration?
Is it possible to use D00_MOSI_0 (AC7), D01_DIN_0 (AB7), CCLK_0 (AA9), and RDWR_FCS_0 (U7) as user IO after configuration is done?
Re: Can I use SPI config pins as user IO after configuration?
I think there is a bit of confusion here. If you say user I/O then we assume you mean general purpose I/O after configuration. We call those dual-mode I/Os. However, you can read/write from/to the SPI flash to your application after configuration. Use the STARTUP primitive to control the appropriate pins required to control the Flash. I think there are appnotes that can guide you in that. I believe XAPP1280 may be your best bet. Or XAPP1191, but that has a lot more in it than just read/write/erase SPI. You could extract what you need from that one as well.
Hi @qubits1
Which device are you using? Check the respective configuration user guide.
If the pin is mentioned as multi-functional, then you can use them as general IO post configuration.
Thanks,Vijay
Scholar pratham
@qubits1
" D00_MOSI_0 (AC7), D01_DIN_0 (AB7), CCLK_0 (AA9), and RDWR_FCS_0 (U7)"
Looks like its Ultrascale device.
No, you cannot. Pin name usually would start with IO_ something similar to below if it could be used as user IO post config.
Example: D4 Pin can be used as a user IO post configuration.
IO_L22P_T3U_N6_DBC_AD0P_D04_65
-Pratham
Visitor qubits1
Thanks. The reason for this question is that I need to access the same SPI config flash device. If I route those same signals to another set of pins on the FPGA, will there contention on the signals? What's the state of the config pins after configuration?
Visitor qubits1
Thanks!
