Can UltraScale DBC/QBC pin be connected to BUFG?
az8888
Re: Can UltraScale DBC/QBC pin be connected to BUFG?
yzha@blueorigin.com,
For DBC and QBC, Only dual purpose GC/QBC pin can be connected to BUFG.
https://www.xilinx.com/support/documentation/user_guides/ug571-ultrascale-selectio.pdf
You can also use any GC pin to connect to BUFG. There are four GC pairs per bank.
See Pg10 of UG572
“There are four GC pin pairs in each bank that have direct access to the global clock buffers, MMCMs, and PLLs that are in the CMT adjacent to the same I/O bank.”
http://www.xilinx.com/support/documentation/user_guides/ug572-ultrascale-clocking.pdf
You can also check this from Vivado package GUI. Open package GUI from elaborated design and under setting, select GC pin as highlighted in below image to find the GC pins per bank.
--Syed
See Pg10 of UG572
--Syed
