iamay88
Can Ultrascale+ Architectures support POD 1.35V?
Refer to UG571 " Ultrascale Select IO", HP I/O Banks support 1.2V POD & 1.0V POD I/O standard.
But I need to use POD 1.35V I/O Standard.
Is there any method to use POD 1.35V I/O Standard with Ultrascale+ ?
gnarahar
@iamay88  Unfortunately there is no support for POD135 IO standard. You will need to use other 1.35V IO Standard and design your own circuit to interface with POD135 RX/TX device.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
