BNicola
Can't build a C++ application with XRFdc
Hi There,
I am using teh RFSoC evaluation board ZCU111.
I recently built an example application (copied it from the rfdc-data-write-example ready available under the project-spec/meta-user/recipes-apps).
I was successfully able to build my own application in C that can access the DACs straight away.
Now I want to immigrate to C++ projects, I used the petalinux-create command to create a C++ template project.
Now when I imported all the C files (data_interface.c, clock_interface.c,......)from the example project and tried to use them in the same way I used it in  my C project it then couldn't build the project.
Here is a snippet of my C++ main.cpp
#include <iostream>
#include <netdb.h>
#include <netinet/in.h>
#include <string.h>
#include <arpa/inet.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include "xrfdc.h"
#include "rfdc_interface.h"
#include "data_interface.h"
#include "clock_interface.h"
#include "rfdc_functions.h"
#define MAX_BUFF_SIZE 800000
#define QB_PORT 8070
#define RF_CTRL_PORT 8081
#define RF_DATA_PORT 8082
#define RFDC_DEVICE_ID  0
using namespace std;
int main(int argc, char *argv[])
   int ret;
   ret = rfdc_inst_init(RFDC_DEVICE_ID);
   if(ret != XRFDC_SUCCESS)
      printf("Failed to initilize RFDC\n");
      return -1;
   else
      printf("===========================\n");
      printf("Initilized RFDC Successfully\n");
   ret = initRFclock(ZCU111, LMK04208_12M8_3072M_122M88_REVAB, DAC_245_76_MHZ, DAC_245_76_MHZ, ADC_245_76_MHZ);
   if(ret != SUCCESS)
      printf("Unable to configure RF clocks\n");
      return ret;
   else
      printf("=================================\n");
      printf("Configured RF clocks successfully\n");
	/*cout << "Hello, PetaLinux World!\n";
	cout << "cmdline args:\n";
	while(argc--)
		cout << *argv++ << endl;*/
	return 0;
Here is my qbcontroller.bb file
# This file is the qbcontroller recipe.
SUMMARY = "Simple qbcontroller application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://qbcontroller.cpp \
           file://board.h \
	   file://clock_interface.c \
	   file://clock_interface.h \
	   file://common.c \
	   file://common.h \
	   file://data_interface.c \
	   file://data_interface.h \
	   file://gpio.c \
	   file://gpio.h \
	   file://rfdc_functions.c \
	   file://rfdc_functions.h \
	   file://rfdc_interface.c \
	   file://rfdc_interface.h \
           file://Makefile \
S = "${WORKDIR}"
DEPENDS = "libmetal"
DEPENDS = "rfdc"
do_compile() {
	     oe_runmake
do_install() {
	     install -d ${D}${bindir}
	     install -m 0755 qbcontroller ${D}${bindir}
And my Makefile
APP = qbcontroller
# Add any other object files to this list below
SRCS=$(wildcard *.cpp)
APP_OBJS = $(SRCS:.cpp=.o)
all: $(APP)
$(APP): $(APP_OBJS)
	$(CXX) -o $@ $(APP_OBJS) $(LDFLAGS) $(LDLIBS) -lrfdc -lmetal -lm
clean:
	rm -f $(APP) *.o
zhendon
Community Manager
Community Manager
Hi @BNicola
What error message did you get when built the project in petalinux?
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
